Thread: Error on opening Autodesk LDD
    2011-02
    Default Error on opening Autodesk LDD
    I get this error lately when I open AutoDesk Land Development Desktop (LDD). LDD still runs fine after canceling the debugger.
    Application does not support just-in-time (JIT)
    debugging. See the end of this message for details.
    ************** Exception Text **************
    System.UriFormatException: Invalid URI: The format of the URI could not be determined.
    at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
    at System.Uri..ctor(String uriString)
    at Autodesk.InfoCenter.CommunicationCenter.PopulateContents(ResultItemCollection& contentCollection, ICommCntrChannel channel)
    at Autodesk.InfoCenter.CommunicationCenter.GetContents(ResultItemCollection& channelContents)
    at Autodesk.InfoCenter.CommCntrSource.InitCommunicationCenter()
    at Autodesk.InfoCenter.PaletteMgr.InitCommCenter()
    at Autodesk.InfoCenter.PaletteMgr.InitPalettes()
    at Autodesk.InfoCenter.PaletteMgr.FirstInvoke()
    at Autodesk.InfoCenter.PaletteMgr.OnAppIdle(Object sender, EventArgs e)
    at System.Windows.Forms.Application.RaiseIdle(EventArgs e)
    at ?A0x2b7cf235.OnIdle()
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3615 (GDR.050727-3600)
    CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    acdbmgd
    Assembly Version: 17.1.0.0
    Win32 Version: 17.1.219.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AcdbMgd.DLL
    msvcm80
    Assembly Version: 8.0.50727.3053
    Win32 Version: 8.00.50727.3053
    CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca/msvcm80.dll
    acmgd
    Win32 Version: 17.1.51.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/acmgd.DLL
    ResourceManagement
    Assembly Version: 11.0.79.0
    Win32 Version: 11.0.079.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/ResourceManagement.DLL
    Redland.NET
    Assembly Version: 1.0.2.1
    Win32 Version: 1.0.2.1
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/Redland.NET.DLL
    AecDtlDb
    Assembly Version: 5.5.256.0
    Win32 Version: 5, 5, 256, 0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AecDtlDb.DLL
    AecDtlDbUI
    Win32 Version: 5.5.256.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AecDtlDbUI.DLL
    AecDtlDbLib
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AecDtlDbLib.DLL
    AcInfoCenterConn
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AcInfoCenterConn.DLL
    AdInfoCenter
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AdInfoCenter.DLL
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    Win32 Version: 2.0.50727.3614 (GDR.050727-3600)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Autodesk.Interop.AcInetEngine
    Assembly Version: 17.1.51.0
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/Autodesk.Interop.AcInetEngine.DLL
    AdInfoCenter.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/en-US/AdInfoCenter.resources.DLL
    Accessibility
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Xml
    Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    ol4djclm
    AcLayer
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AcLayer.DLL
    AcMgdShared
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AcMgdShared.DLL
    acmgdinternal
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/acmgdinternal.DLL
    AcLayer.resources
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/en-US/AcLayer.resources.DLL
    Autodesk.Interop.WSCommCntr1
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/Autodesk.Interop.WSCommCntr1.DLL
    Autodesk.Interop.WebServices1
    CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/Autodesk.Interop.WebServices1.DLL
    ************** JIT Debugging **************
    Application does not support Windows Forms just-in-time (JIT)
    debugging. Contact the application author for more
    information.
    9,706
    Default Re: Error on opening Autodesk LDD
    The "Autodesk.InfoCenter.CommunicationCenter" is a clue that this is related to the InfoCenter. Consider disabling this feature. Google it, based on your version of LDT - for instructions.
    2011-02
    Thanks. Since its at a remote office, I will not get a chance to try till next week. I will post after I try the fix
  1. 2012: Error when opening RAC 2012
    By Clyne Curtis in forum Revit Architecture - General
    Last Post: 2011-08-25, 03:14 PM
  2. Error when opening a file with SP 03
    By S.Agnew in forum Inventor View - General
    Last Post: 2010-05-04, 02:47 PM
  3. Serious Error when opening sections
    By cbukowski in forum Revit Architecture - General
    Last Post: 2009-10-01, 06:06 PM
  4. Error Opening .nwf file
    By jadeonpax in forum NavisWorks - General
    Last Post: 2009-06-08, 03:39 PM
  5. error opening a window
    By mtogni in forum Revit Architecture - General
    Last Post: 2004-11-27, 07:30 AM
