Thread: creating plan and profile sheet
    2011-07
    Default creating plan and profile sheet
    i am trying to create a plan and profile sheet with land desktop 2005. is it possible with this version? i did some about 10 years ago with at that time i believe it was v14 but not sure. it was pretty much automated. created an alignment and selected it and it drew the profile for me
    9,746
    Default Re: creating plan and profile sheet
    Mike321073 - Just a note. I moved your thread over to the Land Desktop forum since your question is about Land Desktop.
    9,746
    You can fairly easily create an EG profile from an alignment in Land Desktop using these basic steps.
    *Create an alignment.
    *Switch to Civil Design menus
    *Under Profiles, choose "Existing Ground > Sample From Surface", follow the prompts and dialog.
    *Under Profiles, choose "Create Profile > Full Profile", follow the prompts.
    EDIT: Now that I reread your post again, you may be referring to a "Quick Section". Just draw a line, select it, right click, choose Quick Section.
  1. 2012: Creating surface profile over Pipe location that is shown in centerline profile
    By karen.cohen593070 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2015-01-21, 11:58 PM
  2. Replies: 0
    Last Post: 2013-04-17, 04:43 AM
  3. Sheet Manager Plan/Profile Some work some don't
    By stacie.61594 in forum AutoCAD Civil 3D - Land Desktop Companion - General
    Last Post: 2010-03-12, 10:33 PM
  4. Non-rotation of plan labels on a plan and profile sheet
    By Capt. Computer Crasher in forum AutoCAD Civil 3D - Profiles
    Last Post: 2009-01-12, 07:13 PM
  5. None plan/Profile sheet generated
    By ramon_tavarez in forum AutoCAD Civil 3D - General
    Last Post: 2008-07-07, 03:52 PM
