Results 1 to 9 of 9
Thread: recovering backups from a workgroup file
    2010-08
    121
    Default recovering backups from a workgroup file
    Are there incremental backups made of a user's local file when they're working from a workgroup central file? I see that there is a folder made on the desktop with the local .rvt file named "<project>_backup" that contains .dat and .rws files but I don't know how to access them. I've tried going to Collaborate>Restore Backup, but that command seems to ask for a folder that contains backup info and I'm not sure where that's supposed to be.
    James
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: recovering backups from a workgroup file
    All you need to do is use the Restore Backup tool and point to that _backup folder
    2010-08
    121
    Quote Originally Posted by dhurtubise View Post
    I do that and nothing appears as if none of the files are of the file type that Revit expects.
    2010-08
    121
    no one has any experience restoring a local backup of a workgroup file?
    2004-08
    Syracuse, NY
    631
    When you use the restore feature it throws you into the backup folder. You need to go up one level, select the backup folder and select Open. You should now see a list of backups with time and date stamps.
    Jason Coe, Architect & Cadd/BIM Lead
    Beardsley architects + engineers
    Auburn, New York
    ____________________________________________
    "Nothing happens by chance and coincidence is when God wishes to remain anonymous"
    http://revitecture.blogspot.com
    2004-08
    Syracuse, NY
    631
    Another thought regarding the restore: When you restore, it is usually best to do a save as. If you restore the current file to a previous date/ time, you cannot undo it and you will remove any progress you made up to the restore date. If you do a save as when you restore, you are saving another file and it will not delete the progress of the backup log.
    Hope that made sense.
    Auburn, New York
    2010-08
    121
    Quote Originally Posted by jcoe View Post
    Awesome! glad you figured that out. Ridiculous you need to jump back a directory and then manually pick the folder that Revit created automatically itself.
    Thanks
    2011-01
    44
    Quote Originally Posted by jameswest77 View Post
    Thanks
    This is honestly the single most retarded thing on the planet. The programmers at Autodesk should be taken out behind the woodshed for this godawful implementation. Shame on them.
    2018-04
    VOLS FAN STUCK IN NOTRE DAME
    13
    Thanks
    Yah it took me a minute to figure this out also.
  1. 2012: frequency of local file backups
    By Twolly in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2012-12-03, 09:19 PM
  2. Recovering Shared Parameter file
    By jsteinhauer in forum Revit Architecture - Families
    Last Post: 2007-12-20, 04:06 AM
  3. Help opening/recovering a .dwg file
    By cadd4la in forum AutoCAD General
    Last Post: 2007-03-14, 03:12 PM
  4. Need help repairing / recovering a corrupt .DWG file
    By IRFANAHMED_01 in forum AutoCAD General
    Last Post: 2007-03-05, 05:24 PM
  5. BATCH FILE FOR DELETING BACKUPS?
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2004-05-03, 01:35 PM
