Thread: Assigning materials on an imported family object
    2010-11
    9
    Question Assigning materials on an imported family object
    Hey,
    I got this family object that was imported from an adsk file. I need to edit the different parts of this object in order to assign materials, textures on them but I can only select the whole object.Whats the solution?
    thanks in advance!
    2004-08
    Syracuse, NY
    631
    Default Re: Assigning materials on an imported family object
    Its my understanding that Revit does not understand "surfaces" of imported CAD geometry. Revit only reads it as imported linework. Exploding does not work with these either.
  1. assigning materials to family parameter
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2011-11-15, 08:55 PM
  2. parametric asignment of materials to imported object in revt ?
    By sst in forum Revit Architecture - General
    Last Post: 2010-05-26, 11:02 AM
  3. Section through a family object and imported dwg file
    By diesellam in forum Revit Architecture - General
    Last Post: 2010-03-26, 02:43 PM
  4. Revit TotD – 7.21.09: Assigning Family Materials, the Direct Approach
    By rkitect in forum Revit Architecture - Tips & Tricks
    Last Post: 2009-07-21, 03:32 PM
  5. Assigning Materials
    By gio_2 in forum AMEP General
    Last Post: 2009-01-13, 08:30 PM
