Thread: Why does offset command break when entering value if the mouse curser leaves the tool bar?
    2010-08
    121
    Default Why does offset command break when entering value if the mouse curser leaves the tool bar?
    Can anyone explain why the offset command gets interrupted while entering a value for the offset if the mouse pointer moves away from the tool bar and into the workspace? More importantly, is there a way to bypass this silly productivity killer?
    James
    All AUGI, all the time DoTheBIM's Avatar
    2005-02
    Central PA, USA
    756
    Default Re: Why does offset command break when entering value if the mouse curser leaves the tool bar?
    I've seen this issue brought up in about every release I've worked on. Only thing you can do is add your name to the list by filing a support request and waiting till they get around to address it.
  1. Allow align command to have an offset value similar to the "pick" tool.
    By autocad.wishlist1734 in forum Revit Architecture - Wish List
    Last Post: 2011-10-05, 03:17 PM
  2. Break Offset
    By prose in forum AutoLISP
    Last Post: 2009-01-06, 02:29 AM
  3. Replies: 1
    Last Post: 2007-02-23, 08:06 PM
  4. Replies: 4
    Last Post: 2006-03-02, 04:13 PM
  5. Mouse Curser Speed
    By dgreen.49364 in forum Revit Architecture - General
    Last Post: 2006-02-22, 06:33 AM
