Thread: Coplaner lines in LT2008-2010
    Default Coplaner lines in LT2008-2010
    Looking to get rid of co-planer lines within some blocks being inserted into LT 2008 & 2010. Flatten command does not appear to be working on these workstations. How do I go about loading up express tools?
    Earth
    9,805
    Default Re: Coplaner lines in LT2008-2010
    AFAIK - there is no Express Tools for LT and no way to load them even if you had the files.
    R.K. McSwain | CAD Panacea |
    What is the best way to remove any non coplaner lines to get everything back to the same plane ie. Z = 0
    Earth
    9,805
    Try this command sequence:
    Command: MOVE
    Select objects: All (or select the objects)
    Specify base point or [Displacement] <Displacement>: 0,0,0
    Specify second point or <use first point as displacement>: 0,0,1E99
    Command: MOVE
    Select objects: P
    Specify second point or <use first point as displacement>: 0,0,-1E99
    0,0,0 The Origin
    8,570
    If you want literally to REMOVE all objects that are not in the xy plane switch to a side, front or rear view and select and delete them. Could depend on the amount by which they are not coplanar with the remainder.
  1. lines non-coplaner
    By shawsf in forum AutoCAD General
    Last Post: 2008-11-17, 11:16 AM
  2. LT2008
    By corbin3james in forum AutoCAD General
    Last Post: 2008-05-23, 05:09 PM
  3. créer plt avec autocad LT2008
    By voegtle.ecogea in forum AutoCAD General
    Last Post: 2008-01-08, 08:29 AM
  4. Comaptibilité Autocad LT2008 et Vista
    By Didier Hoffman in forum AutoCAD General
    Last Post: 2007-07-18, 12:40 PM
  5. fillet/chamfer non-coplaner lines
    Last Post: 2006-01-07, 12:20 AM
