Thread: Visibility
    2011-02
    2
    Default Visibility
    I want to load a created family into a project so that my family is only visible in the 3d view and a 2d image is still visible in plan view. I know it is possible but, how?
    2009-07
    KC
    338
    Default Re: Visibility
    you have to adjust the visibility settings for the different objects in your family, see attached image. select only the 3d geometry in your family and just turn off visibility in the "Plan/RCP" views (and Back/Front, Left/Right if needed).
    For displaying 2d lines only you'll have to play w/ the detail level of the items. I typically turn off visibility of my 3d geometry for "Coarse" and "Medium" but leave checked for "Fine" and turn off visibility of my 2d lines on "Fine" but leave checked for "Coarse" and "Medium" detail levels. Then set the corresponding detail level for your views in the model.
    hope that helps
    looks like I'm now "Ravis.Swargam" - Not sure I can live up to such a strong name.
  1. MEP Visibility
    By antman in forum Revit Architecture - General
    Last Post: 2011-11-07, 06:55 PM
  2. Drafting line visibility, plot pickbox visibility
    By siebenaler in forum AutoCAD Civil 3D - General
    Last Post: 2011-03-07, 03:39 PM
  3. visibility
    By lila in forum Revit Architecture - General
    Last Post: 2007-01-04, 05:30 AM
  4. UI and Visibility
    By sfaust in forum Revit Architecture - Wish List
    Last Post: 2004-08-23, 10:02 PM
  5. Visibility
    By B. Strube in forum Revit Architecture - General
    Last Post: 2003-08-07, 03:24 PM
