Thread: IFC import issues
    2008-07
    Brisbane (Ex. Swedish)
    349
    Default IFC import issues
    Hi,
    I received an IFC file from the architect who is using Archicad. When I open the ifc file in revit some of the walls are not trimmed properly to the roofs but
    when I open the IFC file in BIMsight the walls are OK.
    Is it that revit doesn't read IFC files as well as other programs or is it more complicated than that?
    We have now solved the wall problem with the architect as they apparently have different option for how the walls are being trimmed.
    Thanks,
    J
    2006-05
    836
    Default Re: IFC import issues
    Revit reads the IFC reasonably well, but the issue is it's not trying to read it. It's converting an IFC into an RVT and this is where the issues occur. Things like BIM Sight and Solibri show things reasonably well say from Digital Project, Tekla, Revit, ArchiCAD etc... but back in revit it's alot messier since the shapes are developed and handled differently as well as the relationships.
    Your not opening IFC in Revit your always converting IFC into Revit files.
    2008-07
    349
    Thanks,
    It makes sense but it would be good to be able to have an option to "read" the IFC file and convert it if necessary. Shouldn't complain though - it is a massive help to get an IFC file from an Architect rather than working of dwg files
    Cheers,
    J
    I could stop if I wanted to Baldwin_4-6-0's Avatar
    2004-02
    384
    IFC is a fairy tale with no happy ending yet.
    2020-05
    Archicad handles IFCs very well. The problem lies with Revit.
  1. 2013: "Import detected no valid elements in the file's paper space. Do you want to import from the model space?
    By thomasmerrittgibson397439 in forum Revit Architecture - General
    Last Post: 2013-07-05, 06:53 PM
  2. RISA 3D import/export issues...
    By hand471037 in forum Revit Structure - General
    Last Post: 2012-12-28, 11:59 PM
  3. Replies: 1
    Last Post: 2012-07-09, 03:09 PM
  4. Autodesk Issues Tech Bulletin: Service Issues Affecting Revit9-Based Software
    By jobcaptain in forum Revit - Known Issues & Work-Arounds (Read only)
    Last Post: 2006-05-02, 04:25 AM
  5. Import/export issues in 7.0
    By Chunk in forum Revit Architecture - General
    Last Post: 2004-11-06, 03:54 PM
