Results 1 to 7 of 7
Thread: 2D in CIVIL3D
    2004-08
    Tennessee
    8
    Default 2D in CIVIL3D
    Is there a way to make civil 3d draw in 2d? I am drafting a survey and would like to be able to draw all of my lines at a zero elevation. I have tried using the "flatten" command after I draw a line, but then when I zoom into a point one of the lines comes from, the point and the endpoint of the line are not in the same location. It appears shifted.
    I miss LDD. Autodesk seems to have completely forgotten about the surveyor with it's new versions.
    2009-11
    5,733
    Default Re: 2D in CIVIL3D
    Welcome to the forums!
    It sounds like you're drawing polylines (2D), connecting survey points (which contain a Z value)... resultant polylines (2D) will be drawn with an elevation of the first point.
    Using Civil 3D 2011, the flatten command successfully places both 2D, and 3D polylines at zero (0.00) elevation.
    If the view is shifted, be sure that you are looking in an orthographic view.
    Hope this helps!
    Computer Specs:
    Earth
    9,823
    Quote Originally Posted by MikeMcCulley.RLS View Post
    It's no different than it is in LDT or even vanilla AutoCAD.
    When you pick a point, it will use the current elevation unless you use object snap, in which case it will use the elevation of the snapped point. To avoid this effect, set OSNAPZ to 1.
    R.K. McSwain | CAD Panacea |
    TN/KY Area
    1,640
    Where abouts in TN are you from neighbor?
    2004-08
    Tennessee
    8
    The ONSPAPZ command did exactly what I needed!!!! Thanks a million.
    by the way, JMurphy, I am in Lakeland, Shelby Co
    TN/KY Area
    1,640
    My former area that I covered for Map/Civil support. If you need training let me know I know a good trainer(s) that cover that area.
    2015-12
    Arizona
    2,478
    A different option is to configure the points style to use elevation zero, then one doe not need to set the z snap value at all. This has no impact on the surface created from the points.
  1. Saveas/Export to Civil3D 2010 from Civil3D 2011
    By Openwheeler in forum AutoCAD Civil 3D - General
    Last Post: 2011-07-06, 04:00 PM
  2. 3D Modelling in Civil3D
    By wynand.215409 in forum AutoCAD Civil 3D - General
    Last Post: 2010-07-07, 08:47 PM
  3. Civil3D for who?
    By gcameron in forum Software
    Last Post: 2008-07-28, 04:02 PM
  4. ASD and Civil3D on the same machine?
    By mariepl in forum AutoCAD Structural Detailing
    Last Post: 2008-07-18, 03:43 AM
  5. Anyone using STBs for Civil3D
    By Jas.Bart in forum AutoCAD Civil 3D - General
    Last Post: 2007-08-05, 01:49 AM
