Thread: Dependent view referencing primary view
    2010-01
    2
    Default Dependent view referencing primary view
    Working on an addendum for a project complete in RAC 2011. We have sketch sheets with multiple dependent views from different primary views. Is there a way to have the dependent view reference the sheet and detail number the primary view came from?
    I'm confusing myself just asking. Here's my situation...we're making changes to our demo plans. The same change basically happens on the first and second floor (two seperate sheets...both view #1), so I copied the primaries as dependents, and cropped the view down to the area that's changing. When I drag those dependents onto my sketch TB, it gives the generic view title and just numbers them view 1 and view 2...with no way to reference which sheet and detail number the primary is on. What I want is for one title bubble to say "1/A-051" and the other to say "1/A-052". I've tried using the OTB reference view title annotations, but I can't get it to work.
    I know I could just dummy it up, but I hate doing that. Am I missing something here?
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: Dependent view referencing primary view
    its not referencing because Dependant views are not a callout.
    You can use callout in the parent view, that will give you a reference.
    I hope i understood right, kindda confused too
    2010-01
    2
    The dependent views are partial plans...just the parts that have changed. I didn't want to do a callout because it would show up as a plan detail for the duration of the project...which I didn't necessarily want for an addendum. The thought was to do dependent copies of the plan and crop the region, so as to keep my addendum "sketches" filed under the parent view for future reference to changes made.
    I guess to boil it down, I want the bubble in the view title to have a full view reference (i.e. 1/A-100 instead of just 1, 2, 3, etc.) when I pull the view onto a sheet.
    There's the OTB view title family with a reference bubble...but I don't know how to get the dependent view to reference the parent view so that reference bubble populates correctly.
    That make any more sense? I've attached a screen cap of the view title family with reference bubbles I loaded...basically I want those bubbles to reference the parent view. How do I do it?
  1. Dependent Drafting View
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2014-09-10, 10:56 AM
  2. Associate Primary and Secondary View Template to views
    Last Post: 2012-11-13, 01:51 PM
  3. 2012: Text from parent view in rotated dependent view
    By matt__w in forum Revit MEP - General
    Last Post: 2012-07-03, 03:11 PM
  4. dependent view in section
    By Maximillian in forum Revit Architecture - General
    Last Post: 2008-08-29, 02:12 PM
  5. Dependent View Outline
    By cpiper in forum Revit Architecture - General
    Last Post: 2007-12-07, 05:25 PM
