Results 1 to 7 of 7
Thread: [inventor2008] bend a ring
    2001-07
    319
    Default [inventor2008] bend a ring
    Good morning,
    I'm trying to create a part, a ring
    -inside diam = 350mm
    -outside diam = 470mm
    -thickness = 10mm
    and bend it on a cylinder as a doubling plate. Is it possible?
    thanks
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Default Re: [inventor2008] bend a ring
    The 1st version I used was v2009.
    However, I believe there is an "emboss" function in v2008.
    This will do the trick.
    2001-07
    319
    I've thought about it but I couldn't find a way to make it work
    2015-12
    293
    What are the cylinder parameters?
    2006-04
    1,160
    Quote Originally Posted by clovis View Post
    I think what I told you was wrong.
    Use "Bend Part" function under "Modify" tab, after creating the ring.
    I am not sure if the button may be located in other tag with v2008.
    You have to have an axis on another sketch for bending.
    2001-07
    319
    Yes it might be the solution but I can't make it work..
    I guess I'll see that next week
    Bye
    2006-10
    Use radius instead of diameters. First, cut a section thru the cylinder and from the centre, extend a horizontal line out -any length.
    Next, instead of -inside diam = 350mm, -outside diam = 470mm, change these into radiuses but keep the 10mm thickness.
    Take the radius centre point and position on the horizontal line you drew earlier and preform your manoeuvres off that. Position accordingly.
    From the centre of the part, draw a circle around your cylinder and the use revolve.
    It should become clear so I hope you get what I mean.
  1. ring dish command name
    By 742850517357521 in forum AutoLISP
    Last Post: 2013-02-14, 03:37 AM
  2. 2012: Ring Circuit?
    By micromagic in forum Revit MEP - General
    Last Post: 2011-11-08, 11:40 AM
  3. Bend Line in Flat Pattern Indicate Bend Direction
    Last Post: 2006-05-18, 03:55 PM
  4. Ring Beam Workaround?
    By Justin Marchiel in forum Revit Architecture - General
    Last Post: 2005-12-13, 05:09 PM
