Results 1 to 8 of 8
Thread: Export did not succeed
    2004-05
    7
    Exclamation Export did not succeed
    I am using Map3D 2011 and started getting this message last week. It worked ok since I installed it last spring. The dialog box works as usual and I can use the Automatic selections. It pauses as if to execute but returns this message. Any help?
    T.W.
    TN/KY Area
    1,640
    Default Re: Export did not succeed
    What format are you exporting to? Have you tried an repair install of MAP3D? Any other GIS software installed on the workstation?
    2004-05
    7
    I did repair the Map 3D installation, that's the first thing I tried.
    I also have ArcGIS installed on the computer. It's been running for several years now and I have not upgraded it since last year.
    Something like this happened before with Map 3D version 9, I believe. I was using it ok until I tried to use the "Load Objects" function in ArcInfo. After that the mapexport function in Map3D crashed. The problem went away when I upgraded Map3D. There seems to be a connection betweed the two, but I don't know how that can be possible.
    The strange thing now is that I haven't been using the "Load Objects" function because that doesn't work right either. I am trying to get help from that side too. I have been relying on the Map 3D export to get everything into the GIS for almost a year now but this message just started recently.
    T.W.
    2004-05
    7
    Oops, I forgot. I normally export to ESRI .shp files, but yesterday I tried to export to a ESRI coverage. It worked ok but ArcInfo would not let me edit it because I didn't have the rights.
    T.W.
    TN/KY Area
    1,640
    There is a file in the C:\Program Files\Common Files folder that is used by both AutoCAD MAP3D and ESRI, some how I foget what the fix was or it may be in the C:\Users\XXX\AppData\Local folders. A quick search in the knowlege base didn't help either. You're not running Civil 3D are you?
    2004-05
    7
    No I am not using Civil 3D.
    I found out that the "Load Objects" wasn't working is because ArcMap can't read any .dwg files saved with the recent versions. If I "Save As" a version 2000 file it works ok. Now I can't blame it on ArcMap/ArcInfo.
    I'll look it the folder you mentioned for anything that rings a bell.
    T.W.
    2013-07
    Can you walk me thru creating a shape file? I am a GIS novice. The help file with Autocad isn't helping much. Or I am completely misreading it (very possible).
    Thanks
    C.P.
    TN/KY Area
    1,640
    Quote Originally Posted by c.podesta400519 View Post
    Thanks
    C.P.
    Try this video for a start then ask again if you have questions.
  1. Replies: 0
    Last Post: 2012-07-09, 02:24 PM
  2. Revit Export Issue: Failed to Export Image
    By amax_design in forum Revit Architecture - General
    Last Post: 2009-11-30, 03:13 PM
  3. Export did not succeed
    By monkey5672 in forum AutoCAD Map 3D - General
    Last Post: 2009-07-30, 01:40 AM
  4. Export scale option to support Inch export from metric drawings
    Last Post: 2007-09-19, 04:57 AM
  5. improved dwg dwf export: export design options in hierachical way
    By studiodd in forum Revit Architecture - Wish List
    Last Post: 2007-02-28, 11:15 AM
