Thread: Voltage Drop
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    Default Voltage Drop
    Should be an easy question: Does AutoCAD MEP calculate voltage drop?
    I don't remember seeing it, but since I was asked....
    Thanks!
    2003-02
    1,819
    Default Re: Voltage Drop
    Just to keep this post active (to be answered) I'll ask again. If the answer is just No or Yes that's fine with me... I just need to know how much I need to investigate it (can't find anything indicating that it does, even on-line).
    Thanks!
    2003-02
    1,819
    I never did find the "final" solution to this question. I did find that AutoCAD does calculate the distance between the panel to the device, but in terms of calculations I've not found an answer in how (or if) it's accomplished in the software. Will keep an eye/ear open should an answer be found and will update this when I find it.
    ACA/AMEP Community Chair stelthorst's Avatar
    2003-10
    San Francisco CA
    1,190
    Hi Brian,
    I don't think AMEP will calculate voltage drop (VD). The problem with the "distance" calculation in AMEP is that it only calculates straight line distance from panel to device and doesn't take circuit routing into consideration. However, this can be useful for a "guesstimate of VD. There are many online tools to aid in VD calculations that are free and user friendly. I usually use these when I need to do voltage drop calculations.
    Hope this helps,
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    Some see the glass as half full, others as half empty. As an engineer I see the glass as twice as big as it needs to be. ~Unknown~
    2003-02
    1,819
    Thanks Scott,
    You confirmed my "read between the lines" thoughts after doing a lot of web surfing, reading help documents, reviewing blogs and in general realizing what I WASN'T reading. Since nobody mentioned it as a feature it seemed like it wasn't there, but it didn't show up in any "wish lists" I had tracked down either which seemed equally as strange.
    Thanks again!
  1. 2014: drop voltage and cable setting
    By MEP2 in forum Revit MEP - General
    Last Post: 2015-05-26, 12:19 PM
  2. 2014: drop voltage
    Last Post: 2015-05-26, 11:54 AM
  3. Voltage Drop - How does your firm do it?
    By brad-TEC in forum Revit MEP - General
    Last Post: 2010-06-07, 06:45 PM
  4. [2010] Voltage Drop Percentages (OPEN)
    By heiko.stugg in forum Revit MEP - Wish List
    Last Post: 2010-03-15, 05:38 PM
  5. Calculate voltage drop in Revit MEP
    By baji-gal.ferenc in forum Revit MEP - General
    Last Post: 2009-11-04, 04:12 PM
