Thread: offset and move vertically
    All AUGI, all the time Ning Zhou's Avatar
    2006-08
    636
    Default offset and move vertically
    i have an interesting question from a user referring to difference of OOTB Washer / Dryer, see attached rvt, Dryer has Offset parameter and can move manually in elevation view while Washer doesn't have Offset parameter and cannot move manually in elevation view.
    i didn't notice it before, and just want to know the logic behind it and how to control it when making similar family, thanks.
    2006-08
    636
    Default Re: offset and move vertically
    see reply as below from Autodesk Support:
    "I looked into the issue a bit more and found that the two families were actually created a few years apart, so the offset functionality was something that was original in one but not available in the other.
    As for getting rid of the offset parameter or adding it, it's not possible. It's hard coded into the families and cannot be removed."
  1. Offset/move family from & along the wall
    By EddieFromDc in forum Revit MEP - Families
    Last Post: 2011-07-02, 02:59 AM
  2. Linked model will move horizontally, not vertically
    By nancy.mcclure in forum Revit Architecture - General
    Last Post: 2011-05-02, 08:56 PM
  3. 2D Component will not move vertically
    By Scott Womack in forum Revit Architecture - General
    Last Post: 2009-03-26, 11:05 AM
  4. beam offset vertically
    By wfrst2008 in forum Revit Structure - General
    Last Post: 2007-10-15, 10:14 PM
  5. Mass extrusion won't move vertically!
    By Merlin in forum Revit Architecture - General
    Last Post: 2004-12-10, 02:03 AM
