Thread: some help with a macro expression
    I could stop if I wanted to Doodlemusmaximus's Avatar
    2005-04
    RAT HALL
    298
    Default some help with a macro expression
    some help required pleaqse folks
    i've been trying to set up an expression in the menus that will automatically set the text size dependant on the dimscale. i've had no problems getting the dimscale set to bring in blocks etc but this one has not run at all.
    ^C^C(setq JAM (getvar "dimscale"))
    ^C^C(setvar textsize (cal 2.5*JAM))
    is the last trial but still no joy there.
    2011-02
    15
    Default Re: some help with a macro expression
    hello use (* 2.5 JAM) instead of (cal 2.5*JAM)
    2005-04
    RAT HALL
    298
    Quote Originally Posted by adamnapoleon112151 View Post
    Sorry but this again doesn't work
    2011-02
    15
    i think you missed the qoutation marks "textsize"
    ^C^C(setvar "textsize" (* 2.5 JAM))
    or, you can make it in one line..
    ^C^C(setvar "textsize" (* 2.5 (getvar "dimscale")) )
    2005-04
    RAT HALL
    298
    NOW THAT WORKS
    trying to overcomplicate it one feels
  1. CP222-2: Autodesk Revit VSTA: Writing Your First Macro An Introduction to the Macro Manager
    Last Post: 2014-12-01, 02:12 AM
  2. 2014: CUI Macro with Diesel Expression
    By ccarlson376355 in forum AutoCAD Customization
    Last Post: 2013-06-10, 08:39 PM
  3. Using a Diesel expression in a macro
    By barker_anthony in forum AutoCAD Customization
    Last Post: 2010-10-28, 06:16 PM
  4. Challenging Macro to reverse the function of an existing macro
    By parminderkeilah in forum VBA/COM Interop
    Last Post: 2008-05-19, 02:50 PM
  5. call script within macro & nested macro
    By wahyudin in forum AutoCAD LT - General
    Last Post: 2007-10-22, 01:10 PM
