Results 1 to 6 of 6
Thread: Material Takeoff by Level or by Room
    2007-12
    19
    Question Material Takeoff by Level or by Room
    I'm trying to generate a Material Takeoff schedule, but I need to sort if by Revit Level. I can't seem to do that.
    As an example, I have 3 levels in my model. Each level has a mix of existing and new phases. I want to know the area of gypsum board on level 1. I can get it to tell me gyp. for the entire project, but not just that one level. It would also be useful if I could sort by Room.
    What am I missing?
    Jim
    2009-11
    380
    Default Re: Material Takeoff by Level or by Room
    Create a parameter called "level". Assign the materials and sort as needed.
    2007-12
    19
    Thanks, I had found a similar solution. I'm really disappointed that you can't pull out the base constraint of a wall and utilize that in a schedule.
    All AUGI, all the time DoTheBIM's Avatar
    2005-02
    Central PA, USA
    753
    Quote Originally Posted by jim.155208 View Post
    Agreed. A very long standing complaint/wish list item ( not just on walls either ). Same with scheduling wall height. I'm toying with making my own schedules via ODBC output and can schedule level and wall height as I please via use of queries and reports in MS access. See attached pic. Downside is it's not "live" like it is in Revit.
    2011-11
    4
    Hi - Having the same issue here. Could you detail how you managed to get your walls scheduled by level. I am not familiar with Access.
    2021-12
    What am I missing?
    Jim
    add
    Base Constraint, for level
    - - - Updated - - -
    Quote Originally Posted by fc754823 View Post
    add
  1. Material Takeoff Schedule Sorted by Room
    By ksmith.207733 in forum Revit Architecture - General
    Last Post: 2010-08-05, 02:35 PM
  2. Material Takeoff & Room Schedules
    By Faulkner-S1 in forum Revit Architecture - General
    Last Post: 2009-12-14, 07:04 PM
  3. Material Takeoff does not substract Painted Material
    By joel.196524 in forum Revit Architecture - General
    Last Post: 2009-07-30, 02:15 PM
  4. Material sample in Material Takeoff
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2006-04-26, 09:46 PM
  5. Room schedule & Material takeoff
    By Alvin_Alejandro in forum Revit Architecture - General
    Last Post: 2006-04-22, 08:25 AM
Tags for this Thread
