Results 1 to 6 of 6
Thread: Revit to OBJ?
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Red face Revit to OBJ?
    We need to export a Revit model to OBJ and have the materials/maps carry thru properly to OBJ format.
    We have tried exporting FBX, importing/linking into 3dsMaxDesign, and exporting to OBJ but we can't get
    the maps to show up on the OBJ model.
    Any help is appreciated.
    2011-03
    Toronto
    3
    Default Re: Revit to OBJ?
    did you try any of the presets when importing/linking to 3d max? That should be able to transfer the materials. I would also not import any lighting and cameras from revit to 3d max. Better to do that in max instead imo.
    2004-05
    St. Louis, Missouri
    3,135
    Red face Re: Revit to OBJ?
    Yes--
    We used the Revit preset when exporting FBX for use in Max.
    We did not bring Revit's daylight system/sky, cameras or artificial lights into Max.
    The problem seems to be trying to get MR Protein 2 and Autodesk Materials to transfer to the OBJ
    format out of Max. No luck.
    2007-12
    73
    http://alekcorp.blogspot.com/
    there is the solution and only solution to keep all shaders material and soo on
    work with 2011 export as FBX then export as .obj
    doesn't work with 2012
    Quote Originally Posted by cliff collins View Post
    Hi cliff,
    Hope You are doing well.
    You can try this exporter by using below link:
    Leo
    Hi cliff,
    You can try this exporter(Cadsum OBJ Exporter for Revit) by using below link:
    Leo
  1. New Revit Blog: Revit Down to the Details - Revit COmponent Creation
    By MerryMan in forum Revit Architecture - Families
    Last Post: 2012-06-13, 01:11 PM
