I work for a multi-discplinary Practice of architects, engineers, project managers and cost consultants in the UK. We are currently discussing how to adopt and implement BIM into our standard working practices - currently, we use traditional 2D CAD but want to make the transition in the next few months. The Practice is currently split between MicroStation users and AutoCAD LT users (who switched to Autodesk a few years ago for various reasons). We are trying to decide whether we should adopt Revit or Bentley BIM software. Considering our current mixed Bentley/Autodesk CAD provision, there appear to be pros and cons for going either way.
At present, having completed lots of reading and web-based research, my view is that we should adopt Revit instead of Bentley, mainly due to its popularity, short/shallow learning curve and ease of use, abundance of training literature, number of trained users etc. In the short term at least, Revit appears to be the most expensive option but I am thinking more long term. However, we have a number of conerns about Revit - large file size (too big to email and filling up network storage space), slow operation, hardware requirements etc. Some of our MicroStation users believe that Revit is not as good/powerful as Bentley at 3D modelling.
Having already asked the 'Revit or Bentley' question on the Bentley BE Communities forum (and receiving some surprisingly negative feedback on Bentley Architecture), I thought I should ask the same question on the Autodesk forum....so, after all that text, here goes....
When your company was considering which BIM software (Revit vs Bentley) to adopt, which one did it choose and why?
As this is an Autodesk forum I'm guessing that the answer is Revit, but if you discounted Bentley (especially if you were MicroStation users) it would be good to know why. Another one....
Do you consider that you made the right choice with your BIM software?
All views and opinions would be appreciated. Thanks in anticipation.
Regards,
Stuart Hood
