Thread: Converting ABS entities to ACAD solids?
    2004-11
    Tri-Cities Washington
    20
    Smile Converting ABS entities to ACAD solids?
    Is there a command to convert ABS entities, i.e. ductwork, to ACAD solid entities. The reason I ask is if this will decrease the overall file size. I'm currently working with an increasingly large file and would like to keep the visual aspects without the attributes or anything else that would increase the overall size. Any input would be appreciated.
    2004-11
    20
    Default Re: Converting ABS entities to ACAD solids?
    I have located a sollution. Went to the help menu, and found a tool called "convertto3dsolid". This is a pallet button that can be found in the Autodesk Architectural Desktop Stock Tools Catalog, under the Modeling Tools category. I was trying to convert the Aec Objects to solids because when scale is commanded, the machine locks up, so I didn't really know where the problem starts. My thought is that it had something to do with the attributes that are associated with each part of the ductwork. Reguardless, "converto3dsolid" worked to convert the objects into solids, but I did have some problems with certain parts like dampers, and mvparts. So I just completely got rid of them for now.
  1. Converting ACIS solids to pipes
    By pirit4 in forum Revit MEP - General
    Last Post: 2011-01-27, 08:21 PM
  2. Converting 3d surface to 3d solids
    By pnoy2its176911 in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-10-15, 02:29 AM
  3. Converting MEP ducts to 3D solids
    By jrudolf.157559 in forum AMEP General
    Last Post: 2008-02-08, 07:51 PM
  4. Converting 3D polylines to surfaces or solids
    By Darren Allen in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-12-05, 02:17 PM
  5. Mass Elements vs. Acad 2007 Solids
    By dhallett in forum ACA General
    Last Post: 2006-10-09, 03:51 PM
