Thread: Material cut from concrete column in elevated column schedule
    2005-12
    70
    Default Material cut from concrete column in elevated column schedule
    I have an elevated column schedule w/ concrete columns and when these columns touch slabs or concrete walls the material is removed in the elevated column schedule. Is there a wat to show your column uninterupted. I am providing a jpeg to help understand my question better.
    Thanks for any input
    Keith
    2006-05
    836
    Default Re: Material cut from concrete column in elevated column schedule
    You have to uncut or create openings in the sloabs around your columns.
    Revit 2012 has some options in the families that will allow you to setup columns and beams in this fashion.
  1. Concrete Graphical Column Schedule
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2012-06-21, 09:19 PM
  2. Concrete Column Schedule
    By ckeelor in forum Revit Structure - General
    Last Post: 2010-11-17, 02:18 AM
  3. Graphical Column Schedule (Concrete)
    By david_peterson in forum Revit Structure - General
    Last Post: 2010-04-30, 03:48 PM
  4. Trouble Attaching Steel Column to Concrete Column Below
    By amiller.223744 in forum Revit Structure - General
    Last Post: 2009-09-02, 03:13 PM
  5. Graphic Column Schedule for Concrete Columns/Origin
    By djn in forum Revit Structure - General
    Last Post: 2007-12-13, 03:08 PM
