Thread: "-" minimize function
    6
    Default "-" minimize function
    I frequently am typing in feet & inches.
    When I type a "- sign" screen want to minimize.
    How do I turn off this function?
    It is a PAIN IN THE ***. Enough said.
    Has someone already figured this out?
    Thanks in advance,
    John B.
    6
    Default Re: "-" minimize function
    Answer: It appears that you just have to hit the Insert key while no command is active.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    This link should help:
    http://forums.augi.com/showthread.php?t=128052
    Look at the menu and you can see pressing the ALT key toggles menu shortcut underlines on/off. With them off you should be ok.
    2005-06
    in the upper right corner
    3,508
    Quote Originally Posted by jberghuijs View Post
    Thanks for the tip. I've been having the same issue for months and never knew the reason or a solution.
    Do you (we) know why in Acad 2011 this is happening?
    Is there a more permenant fix or will just hitting "insert" once do it for good?
    Or do we need to hit the insert key everytime we want to use the "-" key?
    2005-06
    3,508
    Thanks for the link Tom, I'm glad to see it wasn't just me.
    I guess I'll need to look if my ALT is toggled on or not next time, plus the "insert" key trick works too.
  1. Function "order and resize array" not returning values
    By CADfunk MC in forum VBA/COM Interop
    Last Post: 2015-01-06, 02:06 PM
  2. 2012 JPEG Resolution in function "Points of view report"
    By the_djodjo351945 in forum NavisWorks - General
    Last Post: 2013-01-21, 03:29 PM
  3. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  4. Minimize "Duplicate Types" dialogs with Copy/Monitor
    By Steve Cashman in forum Revit MEP - Wish List
    Last Post: 2007-03-08, 04:47 AM
  5. Replies: 4
    Last Post: 2006-11-10, 03:50 PM
