Thread: Importing and setting "Default" page setups
    2007-07
    Minnesota
    75
    Question Importing and setting "Default" page setups
    Hey all -
    We recently renamed a couple of our printers (8 1/2x11 and 11x17) in my office, so now all of my page setups are invalid. I have created a new page setup, and would like to import that into several projects. Is there a way to quickly and easily import the new setup, and set as default? I can still use Publish to print them, but would rather not have to open each file and import (as well as dealing with the 'Printer Not Found')
    Thanks.
    Earth
    9,757
    Default Re: Importing and setting "Default" page setups
    The ._Psetupin command can import them.
    To set current, you can use the -plot command (assuming you are wanting to do this using a script).
    R.K. McSwain | CAD Panacea |
    2007-07
    Minnesota
    75
    That helps, but it's not quite what I was looking for. I know how to import Page Setups into a drawing file, but I am looking to import a page setup into a batch of files at once. I have a lot of sheets to update, and was looking to speed up the process.
    Earth
    9,757
    That is what I had in mind with my reply. Use Psetupin and -plot in a script, then run the script on your set of drawings.
    2007-07
    Minnesota
    75
    Thumbs up Re: Importing and setting "Default" page setups
    ahhh... Gotcha! Thanks, that was what I was looking to do. Thanks!
  1. "Default Sill Height" changes the "cut plane" display of the Window!!!
    By stellarblue153 in forum Revit Architecture - Tips & Tricks
    Last Post: 2013-05-06, 07:07 PM
  2. Setting to set "disallow join" for walls as default
    Last Post: 2009-02-01, 07:09 PM
  3. importing page setups
    By rstiles in forum AutoCAD General
    Last Post: 2007-08-16, 10:23 PM
  4. Importing Page Setups
    By hostetterkl in forum AutoLISP
    Last Post: 2005-08-19, 10:23 PM
  5. Importing a layout also imports the named page setups
    By jpaulsen in forum AutoCAD Wish List
    Last Post: 2005-02-17, 04:29 AM
