See my blog at http://cadalot-revitlearningcurve.bl...evit-2012.html
If you are also having problems with printing or plotting with KIP 3000 or HP Plotters and printers then please let me know.
We're got a KIP 7700 and haven't had any issues plotting from RVT 2012.
Used to have issues plotting drawings with images from 2011, but that appears to have been resolved.
Can you try pressing the properties button to the right of the printer name in the print dialogue box and see if your Revit crashes please.
Hi Vgonzales
We have sorted out the print quality issue by configuring revit so that we get what we want, when I get back to the office after the easter break I can send you a copy of our template for you to examine if you wish.
As you have a KIP 3000 can you try pressing the Property button for me and seeing if your Revit or AutoCAD 2012 also crashes.
I've tried from two different pc on our network, It would be good to know if this is restricted to Revit Structure or perhaps the UK version or does it apply to all versions no matter where installed.
Our PCs and operating systems are still 32 bit
After some investigation we have been informed that a Revit 2012 compatible driver is to be released “imminently” so keep on checking the KIP website for updates:-
I'm still trying to find out how imminent "imminently" is?
http://www.kipuk.com/software_downloads.asp?sid=4
We aren't getting the crashes as mentioned here, but we do end up with non-responsive buttons while trying to print (to any print source) as of lately for any file. We think it may be driver related seeing a few other post on the web, but we're working on it and hoping theres a fix.
64bit W7 RST12 with Update2
