Hi!
I am doing a project in 2012. I have an error message of "No Loss Defined" - I imported Plumbing Fixture from Autodesk seek. I am looking for the parameter that will cure the error message but I can't find it. Anyone know what it is?
Hi!
I am not sure what it means but I was able to get rid of the message. You have to edit the component and remove any electrical/plumbing/mechanical info that it is trying to connect to. I guess if your MEP consultants was using Reivt and you wanted them to be able to make their connections to what you have in your model you would need this. I didn't feel a need for them so I deleted them in the component, reloaded into the model which does not overwrite all the parameters. So I had to delete the old ones and insert the new componets without the connection info. Hope this helps.
