Results 1 to 6 of 6
Thread: AutoCAD startup
    2007-11
    Rapid City, SD
    5
    Default AutoCAD startup
    I was wondering if there is a quicker way to open AutoCAD...
    When you start AutoCAD it defaults to a new file using a template file, then you have to close it and open the file you want o work in.
    Is there a way to make AutoCAD not do this and open the "OPEN" dialogue box instead?
    just something i was thinking aobut to save some time.
    2001-12
    St. Louis
    5,319
    Default Re: AutoCAD startup
    Quote Originally Posted by sdeyo View Post
    No, there isn't.
    I tend to open mine from Explorer.
    (see also thread "Open drawing upon start-up instead of drawing1" - http://forums.augi.com/showthread.php?t=4016 )
    Cheers!
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use Revit and Tririga, too)
    Technical Editor
    2007-11
    Rapid City, SD
    5
    thanks. i figured that was the case. i was hoping for something like Revit.
    2001-12
    St. Louis
    5,319
    Thumbs up Re: AutoCAD startup
    No problem. It does seem a bit odd that they've got variables that will control just about everything under the sun in AutoCAD, but, that we can't control that. ~shrug~
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Super Moderator rkmcswain's Avatar
    Earth
    9,746
    Actually, as soon as you open an existing drawing, the "drawing1.dwg" will close, as long as no changes were made to it - so you will end up with only one drawing open.
    Yes, set the system variable STARTUP to 1
    In 2012, you can set STARTUP to 2 to start with no template, but the OPEN dialog will not show up automatically.
    R.K. McSwain | CAD Panacea |
    2007-11
    Rapid City, SD
    5
    that is what i was looking for, STARTUP.
    thanks
  1. How can I make a startUp Exe for Startup AutoCAD
    By 740176597380946 in forum ARX
    Last Post: 2013-05-24, 05:36 AM
  2. 2012: AutoCAD Warning at Startup
    By heinsite in forum AutoCAD General
    Last Post: 2012-12-26, 08:01 PM
  3. AutoCAD Startup
    By EddieS in forum Dot Net API
    Last Post: 2011-07-18, 05:50 AM
  4. AutoCAD 2012 and S::STARTUP
    By rbt in forum AutoLISP
    Last Post: 2011-06-22, 04:27 PM
  5. Run a command at AutoCAD LT Startup
    By Inferno6919 in forum AutoCAD LT - General
    Last Post: 2006-11-23, 10:29 PM
