Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Lisp to "Display plot styles" on open
  1. #11
    I could stop if I wanted to jpcadconsulting347236's Avatar
    2011-09
    300
    Default Re: Lisp to "Display plot styles" on open
    BlockBox - could it be done as a toggle? (I'm thinking single icon on the tool palette to toggle back and forth). Thanks as always!
    Couple of things....
    Unless I am overlooking something (which is entirely possible), there's no need to call vl-Catch-All-Apply when setting an Object's Property (in this case a Boolean), given that you've hard-coded an allowable value (in this case :vlax-True).
    I would, however, recommend that one do so (that is, to use vl-Catch-All-Apply) if passing a parameter to the Object's Property as a value; just not needed here IMO.
    Also, one need not release internal Object's; only external/interface Objects.
    (defun c:ShowPlotStyles ( / acDoc)
      (vlax-for oLayout
                (vla-get-layouts
                  (setq acDoc
                         (vla-get-activedocument (vlax-get-acad-object))
        (if (/= "Model" (vla-get-name oLayout))
          (vla-put-showplotstyles oLayout :vlax-true)
      (vla-regen acDoc acAllViewports)
    Separately, this could easily be expanded to incorporate a bit-coded setting, either drawing data (via XRecord?), or registry data to allow one to programmatically toggle the ShowPlotStyles Property value at drawing open, and/or while in session if desired
    Psuedo system variable:
    0 = All Layouts do not display plot styles
    1 = All Layouts display plot styles, except for Model
    2 = All Layouts display plot styles, including Model
    James Pertusi
    CAD Applications Consultant
    1 (646) 773 4834
    www.jpcadconsulting.com
  2. #12
    Tallahassee, FL
    3,359
    Quote Originally Posted by jpcadconsulting347236 View Post
    Try this:
    (defun c:ShowPlotStyles (/ acDoc ctab)
      (vl-load-com)
      (setq acDoc (vla-get-activedocument (vlax-get-acad-object))
            ctab (vla-Item (vla-get-layouts acDoc)(getvar "ctab"))
      (vlax-for oLayout (vla-get-layouts acDoc)
    	(if (= (vla-get-ShowPlotStyles ctab) :vlax-true)
    	  (vla-put-showplotstyles oLayout :vlax-false)
    Ph# (850)606-1516 Home Page
  3. #13
    2011-09
    300
    Works like a charm! Thanks.
    BTW - reactors are making my head hurt...
    James Pertusi
    1 (646) 773 4834
  1. Replies: 8
    Last Post: 2012-08-18, 01:31 AM
  2. Plot Styles Change "Normal" globaly in layer dialog
    By elowe494 in forum VBA/COM Interop
    Last Post: 2012-01-11, 02:18 AM
  3. Replies: 5
    Last Post: 2009-04-17, 10:10 AM
  4. "SketchUp" like display styles
    Last Post: 2008-07-04, 11:38 AM
  5. Replies: 8
    Last Post: 2007-04-04, 12:39 PM
