Thread: Column - Wall
    2007-09
    Raleigh NC
    755
    Default Column - Wall
    I have a column that is being cut by a wall. How can I prevent that, thanks.
    I could stop if I wanted to Teresa.Martin's Avatar
    2004-11
    438
    Default Re: Column - Wall
    Quote Originally Posted by bryan.thatcher View Post
    Are you using an architectural column or a structural column? They do behave differently. In general, if you do not want a wall to cut or join to a column so to speak, using a structural column is a better choice.
    2007-09
    Raleigh NC
    755
    It's a structural column, a rectangular concrete column that I'm using as a pier. The pier will be in place before the wall, so the wall will be built around it. The other wall that's in the image is linked in, that's why it's not interacting with the 'pier' at all.
    2004-11
    438
    So, my understanding is you are looking for a way for the wall to clean up through a link?
    2007-09
    Raleigh NC
    755
    Well my initial question was to get the column to cut the wall in the same model. My next question would be how to get that to happen through a link. I was guessing I may have to modify the wall in the linked file.
  1. wall and column
    By diesellam in forum Revit Architecture - General
    Last Post: 2010-08-17, 03:53 PM
  2. Wall and Column bug
    By david_peterson in forum Revit Structure - General
    Last Post: 2010-02-08, 02:55 PM
  3. wall/column schedule
    By comma.zhr in forum Revit Architecture - General
    Last Post: 2009-10-08, 06:33 AM
  4. column in a wall
    By xiqx in forum Revit Architecture - General
    Last Post: 2008-06-05, 01:34 PM
  5. Column & wall cleanup
    By Griff in forum Revit Architecture - General
    Last Post: 2004-09-03, 03:28 PM
