Howdy All--
Apologies if this is a redundant topic...I have searched both the current and archived postings but have yet to find a solution to this issue. I am hoping to find a way to add a "bottom of elevation" parameter to my custom beam tag that shows the "real world" (ie. site) elevation. Specifically I am thinking of cases involving grade beams (I have been modeling with concrete beams, therefore a foundation tag with a bottom of elevation parameter will not tag the beam) where we wish to indicate the depth of excavation.
I understand that the spot elevation tool can do this, however I would ideally want one single tag to reflect both size (type mark) and elevation without having to manually input the elevation. I tried adding an elevation parameter to the beam family itself as a shared parameter, but cannot figure out how to create a tag that can capture this information. Clearly there has been some discussion of this on AUGI but without a solution as far as I can tell.
Thanks
