Hi All,
I am having a weird problem with the pipe fittings.
For some reason when I draw a pipe and then turn 90 degrees, it creates the 90 degrees elbow but the elbow apears smaller than the pipe (I attached a pdf showing what I mean), and it also happens with the tee fitting, I am using the standard pipes fitting from revit and I did a previous project where I didn't have that problem, but the project that I am currently working on, I wasn't the one who set it up and our office got it from another office to continue working on it, so I tried looking in the settings of the file but couldn't figure out what is the problem. This problem only happens with pipes, ducts are fine. Also when I try to change the size of the elbows or tees the fitting size doesn't change visually, it only changes in the properties bar but it doesn't get smaller or bigger on the monitor and in the print out..
Please let me know if you have an idea..
Thanks to you all for the help.
