Hi guys,
I'm using revit architecture 2011, my project is in "meters". both plans and sections are scale 1:50.
My problem is, I don't know how to open my work "to scale" in photoshop. I am required to print all my work on one 2.2mx5m board. The reason for photoshop is that I also need to render my work there, along with some 3ds max shots.
I tried exporitng to CAD, opening from CAD & plotting to PDF, then opening it in photoshop, but the scale was all off, & the qualitiy was very bad.
I also tried adding a title sheet in revit, but my work was much bigger than all the sheets I had. I don't know if it's a measure unit issue or not.
To summarize my question: How can I open a revit file (in pdf format for example) in photshop, while keeping it to scale?????
What can Ido to fix this? If anyone could lead me to a solution to this, I'd be more than greatful.
Carrie
