Until recently we had been using VoloView for viewing drawings by non-engineers, mostly for generating PDFs to send to vendors for purchasing.
Last week we discovered it had been replaced by TrueView so we d/l'ed it and installed it. Other than having a larger footprint, it has been working relatively well. However today we ran into a drawing that is causing a problem.
We have a drawing that has several reference measurements, designated with letters in a circle. When viewed in Mechanical 2004, they render just fine. In Trueview 2012 however, the circle renders "cutting thru" the letter, as I show below.
I asked the engineer if this could be "re-rendered" or "re-generated" (not sure if that is the right term) but that didn't seem to make any difference.
Any idea what might cause this, and what a solution might be?
Any help is appreciated!
