Results 1 to 6 of 6
Thread: Double sheets in list
    2007-09
    Raleigh NC
    755
    Default Double sheets in list
    For some reason my model is showing up twice in the sheet list. Can anyone think of a reason this would be happening? Is it a problem with their file or my model? Thanks.
    2004-06
    Memphis TN area
    7,048
    Default Re: Double sheets in list
    I'm not sure what you mean. Only sheets show up in sheet lists, not models or model views. Do you mean that you have a linked file and the sheets from both files show up in your sheet list? If so, open the properties for your sheet list and under Fields at the lower left is a check box to include elements (sheets in this case) in linked files.
    2015-10
    Denver, CO
    34
    I am guessing you are talking about your sheets showing up twice in your project browser. If this is the case it's a default setting when setting up the project.
    In your project browser hover over the Sheets, right click and hit the type properties option. Click folders and change your settings to Group by 'Sheet Discipline', then none. Sort by 'Sheet Number'.
    If your workplace is not lax about altering standard settings make sure you duplicate before making changes.........Since our last upgrade I have been noticing this at the firm I am currently working at.
    2006-01
    93
    Hi! We were having this same issue a week ago with our linked files - with no explanation. We finally ended up going into the "Sorting/Grouping" in the sheet list properties and clicking off "itemize every instance".
    Not sure why the sheets were showing up twice...clearly, I only had one sheet named and numbered one way (Revit doesn't let you do otherwise)
    Hope this works for you.
    -Heather
    2004-06
    Memphis TN area
    7,048
    Quote Originally Posted by hworrell View Post
    -Heather
    Did you have 2 or more files started from the same template linked together with some sheets already in each file? If so I bet you had "Include Elements from Linked Files" checked under the Fields tab.
    Keep in mind also that if this above is true and you simply turn off Itemize Every Instance, then if one sheet has a different name from the same sheet in another linked file, the sheet title will not show up.
    I have Itemize Every Instance checked on my sheet list, with no linked files, and everything shows up correctly.
    2016-02
    4
    I had same problem. Your answer worked for me on R16
  1. Removing the double list pairs
    By Ehsan in forum AutoLISP
    Last Post: 2012-07-16, 03:47 PM
  2. Linked Drawing List Schedule showing double sheets
    By troy.crandell635379 in forum Revit Architecture - General
    Last Post: 2010-04-09, 08:16 AM
  3. Drawing List - Not Adding Existing Sheets
    By sroy in forum Revit Architecture - General
    Last Post: 2009-06-30, 01:27 PM
  4. Drawing List w/ Sheets from other projects
    By jcoe in forum Revit Architecture - General
    Last Post: 2008-05-08, 05:59 PM
  5. Revision Dialogue - List issued sheets
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2005-06-01, 12:54 AM
