Thread: burst, explode attributes to text
    Member thoff's Avatar
    2007-01
    Lou., KY
    12
    Default burst, explode attributes to text
    Anyone know if these commands are in MEP 2012?
    I could stop if I wanted to stykface's Avatar
    2007-11
    Dallas, TX - USA
    352
    Default Re: burst, explode attributes to text
    Quote Originally Posted by thoff View Post
    Yes. It's apart of the Express Tools addon. During installation make sure this option is checked.
    Tannar Frampton | Dallas, TX | Engineering Department
    AutoCAD MEP 2012 / Revit MEP 2012 | CADTutor | The Swamp
    2007-01
    Lou., KY
    12
    Thanks, is this something that I can still do, after installlation is completed?
    2007-11
    Dallas, TX - USA
    352
    You sure can. Insert the installation disc and through the Add/Remove programs feature, you can run through the installation selections when it asks you to customize the installation. From there you can check the box that will install the E.T.'s
    2007-01
    Lou., KY
    12
    thanks very much
  1. Convert Explode command to Burst command?
    By stusic in forum AutoLISP
    Last Post: 2013-06-18, 11:55 PM
  2. 2008: Possible to Explode/Burst Blocks and Maintain Xclips?
    By ReachAndre in forum AutoCAD General
    Last Post: 2011-11-09, 01:01 PM
  3. burst vs explode
    By SCR73 in forum AutoCAD General
    Last Post: 2009-04-23, 03:44 PM
  4. use BURST instead of EXPLODE
    By ceekayem in forum AutoCAD Tips & Tricks
    Last Post: 2006-01-20, 05:21 PM
  5. Using BURST instead of EXPLODE
    By ryan.87191 in forum AutoCAD General
    Last Post: 2005-09-12, 09:35 PM
