Hi all,
Created a whole bunch of deployments for revit 2012, and am running into a little bit of trouble when it comes to the client installing it.
Note: This doesnt happen with all clients, only a select few.
The issue being is that a client will begin installing the program & within 30 Seconds the install will just drop out. No matter how many times you try to do this it will always happen.
I played around with the deployments and removed autodesk design review from the deployment and found that it worked.
I dont know why this is but i was hoping for some feedback here. I cant leave the deployment excluding design review because then the client has to manually download the program.
Thanks in advance.
