Thread: Creating flat pattern of tube end profiles with frame generator
    2011-04
    12
    Default Creating flat pattern of tube end profiles with frame generator
    I've designed a 3D space frame with about 30-40 tubes. Each tube has a unique end profile since it is not a rectilinear frame.
    Is there an easy way to create a "flat pattern" of the profiles of the end of the tubes in Inventor? I think there is a way to do this by converting the part to a sheet metal part, ripping and then unfolding it. But that will be very time consuming to do for all the frame members.
    It seems like there would be a utility in Inventor to do this. We want to be able to print out this flat pattern, cut it out, and then trace it onto the tubes to grind the profiles by hand.
    Thanks in advance!
    Williamsport, PA
    641
    Default Re: Creating flat pattern of tube end profiles with frame generator
    You will have to do one-by-one as you describe.
    Alternatively you could create your own custom profile for the frame generator with a rip in the profile from the start.
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    AU 2007 Avatech Altogether Smarter Inventor On-line Challenge 1st Place
    Autodesk Inventor Certified Expert
    Certified SolidWorks Professional
    Williamsport, PA
    2011-04
    12
    That's what I was afraid to hear...
    Thanks for the reply.
    Quote Originally Posted by JD Mather View Post
  1. Customized Profiles for the Frame Generator
    Last Post: 2012-12-15, 05:20 PM
  2. Ability to Add More Profiles to Frame Generator
    Last Post: 2012-12-15, 03:51 PM
  3. Tube & Pipe/ Pipe Sections to work like Frame Generator on BOM
    Last Post: 2011-11-02, 08:51 PM
  4. 2011: Frame Generator - Trimming to frame member that is a bent tube
    By dcook87725927 in forum Inventor - General
    Last Post: 2011-04-27, 02:41 AM
  5. Ability to Create Custom Profiles in Frame Generator
    Last Post: 2007-01-02, 06:19 PM
Tags for this Thread
