Thread: Human Figure For Ergonomic Study (Elevation)
    All AUGI, all the time SRBalliet's Avatar
    2004-06
    Near Christiansburg, VA Looking for a closer job!
    500
    Default Human Figure For Ergonomic Study (Elevation)
    Because of time constraints, this figure is not the best it could be. But it is fun to play with!!! If you make a bunch of pose changes and then use undo multiple times, you can make him/her dance.
    Known issues:
    >Joint at base of thumb was left out.
    >When certain body parts are moved they either leave gaps or overlap. (I have seen other blocks that use a mask which would probably work here and some stretch parameters would take care of the gaps.)
    >I could also have restricted rotation angles to prevent dislocations or broken bones.
    For my purposes these items were not needed, if someone wants to run with it, be my quest and share it back here.
    I am now working on a figure for plan views and one for a side view (like sitting at a desk). Let me have your ideas and if I know how to do it, I will try to incorporate them.
    2010-06
    91
    Default Re: Human Figure For Ergonomic Study (Elevation)
    That is really cool!
    2019-02
    Hi, I know this is long time from original post, but have you finished side view figure drawing?
    2004-06
    500
    Quote Originally Posted by jacek.pluta779380 View Post
    Never finished it. I have attached the side view as I left it. I hope it is of some use to you.
    2011-01
    Nice work, it was great just being able to sit him down at a table
  1. Human Figure Version 2 Front, Back, Side
    By SRBalliet in forum Dynamic Blocks - Sharing
    Last Post: 2011-10-30, 05:35 AM
  2. Human Figure help with rotate and stretch
    By SRBalliet in forum Dynamic Blocks - Technical
    Last Post: 2011-06-08, 08:27 PM
  3. Human Figure For Ergonomic Study (Side View)
    Last Post: 2011-05-27, 06:36 PM
  4. Need human figure blocks or files
    By coondog45 in forum AutoCAD General
    Last Post: 2007-09-13, 02:42 AM
  5. Spot Elevation Layers, Can't Figure This Out!
    By ccoles in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2007-06-12, 06:11 PM
