Navisworks info is so hard to find online, espcially due to the content blocker my emplyer uses. However, I did find a site that had strarted a Survival guide. Sadly it only had 3 entries. Perhaps we could start one.
Here is my request:
Every user most post at least on cool tip or trick to this thread
Here is mine:
Remember that Navisworks is dumb, as in it is not smart. It really doesn't anticipate your next move like Revit, picture Navisworks like a lazy sloth. For example if you set the select & search function to geometry you won't get Revit related properties from that item anymore, nor will they appear in your freedom viewer model. To get the revit properties, set the select & search to last object.
