When opening drawings in TrueView, the plotstyle is applied. In some cases this makes the dwg unviewable because the line weights shown are too thick. In AutoCAD 2012, by default, I turn this (showplotstyles) off. If the dwg is saved with it turned off I can then view it in TrueView with no problem. However if it is turned on in the dwg, there doesn't seem to be a way to turn it off in TrueView.
Is it impossible to do this in TrueView or am I missing something?
