Thread: Human Figure help with rotate and stretch
    All AUGI, all the time SRBalliet's Avatar
    2004-06
    Near Christiansburg, VA Looking for a closer job!
    500
    Default Human Figure help with rotate and stretch
    I have two figures in the Sharing Forum that I need help with. The problem is at the joints. For example when I rotate his head, gaps appear at the joint along the body outline. Is there a way to make those ends stretch and fill in the gap created when you rotate. It happens in a few places along the outside of the body. Any ideas?
    Steve Balliet
    Craig Co., VA
    Civil 3D, Mechanical 2012
    Active Member sandrews.253556's Avatar
    2010-06
    91
    Default Re: Human Figure help with rotate and stretch
    What about leaving no gaps and using wipeouts under each body part that rotate with it?
    2004-06
    500
    I also thought about that but wipeouts and draw order are such a pain and sometimes lose their draw order. I was hoping there would be another solution.
    Steve Balliet
    Craig Co., VA
  1. Human Figure For Ergonomic Study (Elevation)
    By SRBalliet in forum Dynamic Blocks - Sharing
    Last Post: 2019-03-04, 12:46 PM
  2. Human Figure Version 2 Front, Back, Side
    Last Post: 2011-10-30, 05:35 AM
  3. Human Figure For Ergonomic Study (Side View)
    Last Post: 2011-05-27, 06:36 PM
  4. Polar stretch or rotate with stretch help
    By Opie in forum Dynamic Blocks - Technical
    Last Post: 2008-08-15, 10:43 PM
  5. Need human figure blocks or files
    By coondog45 in forum AutoCAD General
    Last Post: 2007-09-13, 02:42 AM
