Thread: Can I create a scaleable box in a detail view template?
    NavisWorks Moderator david.kingham's Avatar
    2004-07
    Fort Collins, CO
    1,329
    Default Can I create a scaleable box in a detail view template?
    If that makes any sense....basically I just want a box that would be invisible on the sheet but would change size based on the scale in the view, it is just for users reference so they know what scale to use and for placement on the sheet
    2003-09
    1,907
    Default Re: Can I create a scaleable box in a detail view template?
    The crop box on the view is essentially that. What beyond the crop box are you looking for?
    2004-07
    Fort Collins, CO
    1,329
    We have a grid setup on our sheets that is numbered 1 thru 36, I would like to have the size of one grid in the detail that resizes based on the scale, which also has a line on the right side for text alignment, this way all the text is aligned for each detail on the sheet....am i making any sense?
    I could stop if I wanted to David Conant's Avatar
    2003-05
    Milton MA
    286
    Pictures will save a thousand words. Text descriptions of such things are often too abstract to convey the precise intent.
    David Conant
    Autodesk Revit
    2004-07
    Fort Collins, CO
    1,329
    Ok here is an example of what we use in acad, just different boxes at different scales....if it still doesn't make sense that's ok, Phil will be here in a couple weeks to save us
  1. 2014: create new view template
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2014-03-03, 09:59 PM
  2. Within IDW, Detail View, Create Broken Dimension
    Last Post: 2010-06-22, 12:54 PM
  3. Application ERROR: There are no viewports avaliable to create Detail view
    By alberto.malinverno in forum AutoCAD Structural Detailing
    Last Post: 2010-05-28, 05:24 AM
  4. Replies: 2
    Last Post: 2009-04-23, 03:45 PM
