Results 1 to 10 of 12
Thread: Worksets - How much is TOO much?
    AUGI Addict matt__w's Avatar
    2002-06
    North Central CT
    1,108
    Default Worksets - How much is TOO much?
    Is there a general rule of thumb when it comes to creating worksets? Is there a recommended "maximum number of worksets"? We'll typically have 12-14 worksets.
    Matt
    All AUGI, all the time Ning Zhou's Avatar
    2006-08
    636
    Default Re: Worksets - How much is TOO much?
    my general rule of thumb -> as less as possible
    just like modeling -> only model up to the needed detail level
    I could stop if I wanted to RevitNinja's Avatar
    2007-09
    490
    At one of the AU classes last year, I saw a presenter with 50+ worksets. Every discipline was broken up by area of the building and floor. It was totally ludicrous.
    2002-06
    North Central CT
    1,108
    Yeah... that's a bit over the top. But I guess they're just showing a sort of "worst case scenario"? So I guess our 12-14 isn't too bad then.
    2007-09
    490
    I was very surprised because it was one of the more well-known MEP "gurus."
    It became apparent though that the setup and organization of his Revit projects were completely dictated by how it would function in Navisworks, which doesn't affect most of us here.
    2004-06
    Memphis TN area
    7,047
    In our architecture office (in which most of our projects are pretty small by most standards), we typically do a fairly broad workset setup, i.e. not too many of them. Out typical project looks like:
    CAD Links (off by default)
    Exterior
    Interior
    Revit Links
    Shared Levels and Grids
    Site
    Structure
    We usually do one for thin floor finish objects that show up in finish plans, which we could accomplish with a filter, but we like for those objects to NOT show by default in ALL views except finish plans, so we usually have a Floor Patterns workset that is turned off by default.
    This has been a pretty good system for us as it allows us things like quick life safety or site plan setup with only building exterior walls showing, or a 3D Structure view with only structural elements showing, etc.
    For MEP, I might create worksets for each discipline/system (HVAC, plumbing, lighting, power), and also for Revit links, and for CAD links, and that's probably about it. I'm not sure if I would go much farther than that, workset-wise.
    AERC, PLLC
    Hernando, Mississippi
    2002-06
    North Central CT
    1,108
    Our typical worksets are as follows:
    COOR - Coordination Items
    EL - Electrical Lighting
    EP - Electrical Power
    ES - Special Systems
    FP - Fire Protection
    H - HVAC
    HP - Hydronic Piping
    MG - Medical Gas
    P - Plumbing
    Spaces - Spaces
    TC - Technology (Communication)
    TS - Technology (Security)
    We may add another 1 or 2 depending on the needs of the project or we may merge some together such as TC/TS, EL/EP/ES, H/HP or FP/P.
    2004-06
    Memphis TN area
    7,047
    Sounds like a great setup to me. I forgot about some of those other more "in-depth" systems.
    Curious, what do you use the CORR workset for? And do you also create them with just those abbreviations? I personally would just create them with the more descriptive names.
    AERC, PLLC
    2002-06
    North Central CT
    1,108
    The COOR workset (COORdination items) is for any type of equipment (mechanical, plumbing, etc...) that needs power. So we would have the COOR workset visible in the electrical power drawings but half-tone. This way the electrical designers (who don't always have a complete set - just their drawings) will know that there is other equipment that needs power. Which could lead to additional panels, yada yada yada...
    2004-06
    Memphis TN area
    7,047
    ah nice, is your office total MEP under one roof?
    AERC, PLLC
  1. Worksets HELP
    By Nun_Ya_Bez in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2009-09-14, 09:41 PM
  2. Worksets
    By wags5116 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2009-07-19, 04:21 PM
  3. Worksets
    By adrianocallisto in forum Português - Revit
    Last Post: 2009-06-01, 11:57 AM
  4. Worksets
    By mmenendez in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2007-02-05, 06:00 PM
  5. Worksets with ftp
    By ford347 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2007-01-27, 08:56 AM
