I have one drawing containing my pipe networks. The parts list and part styles were dragged in from my template drawing. So, I can swap a part to a five foot manhole with a five-foot manhole style. The structure property will show a 60" diameter MH with the style MH-5, and a 60" diameter MH block will be inserted on the plan and profile. Everything just as I want and expect.
In my plan and profiles, I data referenced the pipe networks in to add them to the profiles. As in the pipe network drawing, the parts list and part styles were dragged in from my template drawing, so they are identical. The structure properties will correctly show a 60" diameter MH, but the style has been assigned as MH-4, and it will insert a 48" diameter MH block.
This is just an example, and it happens with all types of structures. I can manually change it to the correct style and it is OK. But it won't come in the correct way to start with.
What I have found is that, in my parts list, the MH-4 and MH-5 are in the same catalog (Round Manholes). Whenever the network includes any part from this catalog set (Round Manholes), it will always revert to the first style in the list (MH-4). The same problem exists with catalog Square Inlet, Round Inlet, Water Valves, etc. Any part in a category will have the correct property size, but will always be assigned the style of the first part in the list.
Any body know how to fix?
I'm using Civil 3D 2011 on XP.
Thanks
Scott
