Thread: Tags Rotate With Element in Locked 3D View
    2007-10
    Denver, CO
    105
    Default Tags Rotate With Element in Locked 3D View
    The 3D locking & tagging feature in Revit MEP 2012 is great! It doesn't seem that the tags rotate with the element. For example we typically tag a pipe with the abbreviation on the pipe. It will only allow the tag to read vertical or horizontal.
    2008-05
    3
    Default Re: Tags Rotate With Element in Locked 3D View
    Quote Originally Posted by phil.pleiss View Post
    Dear Phil,
    You can use Revit 3d Tag add-inn. You can see video and brochure links below...
    http://www.grafcad.com/revit3dtag_index.htm
    http://www.youtube.com/watch?v=SqBqDkErkAE
  1. Rotate Tags with Element
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2021-02-24, 04:09 PM
  2. 2014: ROTATE VIEW TO ELEMENT??
    By reddish247450771 in forum ACA General
    Last Post: 2014-04-23, 06:07 AM
  3. Rotate Element in Displace View
    Last Post: 2013-10-04, 04:33 PM
  4. Help me rotate element
    By jsteinhauer in forum Revit Architecture - Families
    Last Post: 2008-03-21, 02:32 PM
  5. Replies: 8
    Last Post: 2005-06-30, 02:32 PM
