Thread: DWF file
    2009-01
    4
    Default DWF file
    I have navis files ext nwd and convert it to dwf files. when open this file by QTO the model open when want to start model take off the following massage appear “Error occurs while start model takeoff. The model sheet may collapse” . Also note that the nwd file had been exported from PDMS system. If anyone can help me to solve this problem or what type of can PDMS export it to start model take off
    2004-06
    77
    Default Re: DWF file
    Hello,
    This is just a guess as I haven't installed the latest (2012) QTO to test, but I'm thinking that QTO is still not designed to handle a DWF that has been published out of Navisworks (for use with automated model takeoff). I have tested the DWFs out of AMEP, ACA and Revit which do support the model takeoff.
    Hopefully someone else will prove me wrong as the workflow out of Navis and into QTO is something I'd love to see.
    Regards,
    Glynnis Patterson, Architect
    www.ideatebimlink.com
    http://www.youtube.com/playlist?p=PL17FF8F775A853DBC
  1. Replies: 7
    Last Post: 2013-11-16, 11:44 PM
  2. 2014: Revit reporting Central File is not available, no one else is in file, can't save, won't create local file
    By patricks in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2013-10-03, 10:31 PM
  3. Replies: 1
    Last Post: 2008-10-14, 02:32 AM
  4. Replies: 0
    Last Post: 2008-10-13, 10:20 PM
  5. Copy from individual REVIT file to workset file (shared file)
    By kkansara in forum Revit Structure - General
    Last Post: 2007-08-06, 05:02 PM
