Thread: Field Attribute Not Updating on .NET Insert?
    100 Club mcoffman's Avatar
    2005-08
    Porland, OR
    128
    Default Field Attribute Not Updating on .NET Insert?
    I have a routine that inserts a dynamic block (title block) into a selection of drawing files. This is done by directly editing the databases, not through the editor MDIActiveDocument interface. Everything works on the insertion except for one attribute that has a field that displays the selected title block size (a dynamic lookup table value). It shows up as a series of "#" signs. If I insert the block within AutoCAD using the INSERT command, everything displays correctly, so I don't think it's an issue with the block itself. My code does go through the attribute collection and initialize all of the attributes, just like all of the sample codes for block insertion demonstrate. I'm at a bit of a loss on how to get this to work right. Any thoughts and suggestions would be appreciated! Thanks!
    Michael Coffman
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Default Re: Field Attribute Not Updating on .NET Insert?
    Have you tried
    Editor.Regen()
    after inserting
    "The whole problem with the world is that fools and fanatics are always
    so certain of themselves, and wiser people so full of doubts."
    Bertrand Russell
  1. 2015: Field in an Attribute not updating
    By derek.96018 in forum AutoCAD Customization
    Last Post: 2015-09-09, 05:06 PM
  2. 2013: Field within block not updating
    By montero1 in forum AutoCAD General
    Last Post: 2015-08-07, 02:13 PM
  3. Trying to insert a field in a titleblock attribute
    By jawf in forum VBA/COM Interop
    Last Post: 2009-09-02, 07:50 PM
  4. Trouble updating date field
    By cdoucet in forum CAD Management - General
    Last Post: 2008-01-16, 04:53 PM
