Hi all,
I would like to know if any of you can help me with this very tricky CAD Management issue I have.
In my company we have an Engineering Dept. which does CAD engineering design (from general arrangement, to detailed fabrication drawings and later 3d models from them). The problem I am facing is that it is very difficult to measure the productivity of the department since we have different equipment all the time.
It is difficult to set Finish Date targets since it is very difficult to assess the difficulty of the task to be done. Then Project Management becomes extremely difficult, with usual delays and cost consequences since I don't know how long it should take to finish a certain work and as a result you have to rely on the speed of the workers (which I know is not good!!). I have surfed the internet a lot trying to find an answer to this, but surprisingly, there are very little (or none) topics about this!
The problem is quite difficult to tackle , but at least I want to start measuring the difficulty of a task once it has been finished (which is easier than to assess it before you don't know exactly how the final drawing will look like!). Then I can measuring performance and in that way start putting in place some well directed incentives and punishments based on workers performance to increase productivity...
So the question is: How do you assess the difficulty of an AutoCAD drawing (after it has been finished) in terms of Man-Hours/drawing? A very gross approximation is enough. I understand it depends a lot on the experience of the draftman but I ened to take that variable out, saying that the same person would do all the drawings.
I was thinking that I could maybe count the lines on the finished drawing to get a correlation of this with the total time taken to finish it? Then using this correlation, with the number of lines of another CAD Drawing I could estimate the time it would be needed to finish it?
Please I am totally open to suggestions. If I am not clear enough, please let me know to further explain.
Thank you in advance,
Hans
