I am trying to setup a level triangle block which uses a an attribute extraction field to obtain it's y position. I have inserted a point into the block and then gone about setting up my attribute. This is where I get stuck, I go to Field>Object>(Select the point)>Position>(Untick all boxes except y). This the reports the dimension in millimeters, which is what I work in, but I would like the dimension to be in meters. I have tried usiong the 'Additional Format' button but it will not allow me to apply a conversion factor.
Any help would be greatly appreciated.
Thanks,
Andy
