I have a simple Dynamic Block with an attribute which I edit to include a sheet number 'field' from Sheet Set Manager. This has worked fine for some time, but recently that field entry moves from the original text location for no apparent reason. For example, the block attribute says "Match Line - See Sht. 9", the "9" is the 'field' and it moves a significant distance below the rest of the text. When I remove the field and just type in '9' it works fine, but that defeats the purpose of Sheet Set Manager coordinating my drawings. Any suggestions would be appreciated, thanks.
