Results 1 to 10 of 12
Thread: Override line color also override weight and style
    I could stop if I wanted to Nic M.'s Avatar
    2001-11
    Antwerp, Belgium
    480
    Default Override line color also override weight and style
    If I only override the color of a line in the visibility/graphic dialog and the other parameters remained by category, they do change in solid, weight 1 lines.
    Is this the intended behavior ?
    I have 2 plans of the same level.
    plan 1 has different lines in different colors and thickness
    plan 2 also need these lines in light grey but I would like to keep the different patterns and thickness.
    Seems like I have to check which pattern was assigned to which line style and set it back in the visibility/graphic override dlg if I change the by category color.
    definitely a wish
    2003-05
    5,153
    Default Re: Override line color also override weight and style
    Nic,
    I'm not able to replicate that behaviour.
    I can over-ride colour, weight and style view specifically or just colour, for example, with weight and style remaining By Category. Or any other combination.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    2001-11
    Antwerp, Belgium
    480
    Beegee, thanks for the assist
    I have attached my findings
    My initial linetype is a fat blue dashed line
    In another view I override this linetype with colour black
    The pattern changes to solid and the thickness changes to 1
    The default Wide linetype overridden to colour red changes the thickness to 1
    If I start from a Thin line and override this to colour , thickness or pattern it changes correct
    2003-05
    5,153
    Nic,
    Firstly, so we are on the same page, what Version and Build are you using ?
    Bruce Gow.
    Architect.
    Revitalize. Blog
    2001-11
    Antwerp, Belgium
    480
    Build 20041213_2030 Rel7.0
    If you start from a solid, black, 1 unit thick line (Thin Line) you can override everything
    if you start from a dashed, colour more than 1 unit thick line if override 1 parameter the other change to solid, black, 1 unit thick line
    are you not experiencing this?
    2003-05
    5,153
    Yes, following that process, I see the same result.
    That's a bug, Mr M.
    Quote Originally Posted by Nic M.
    Bruce Gow.
    Architect.
    Revitalize. Blog
    100 Club studioCJF's Avatar
    2003-08
    Chicago
    106
    beegee
    That is/was a bug in the latest version of 6.1 as well. I found that out just last week when I was trying to change just the color of the lines and ended up loosing all the line weights and styles.
    Actually what I was trying to do was adjust the color of the halftone and found out by searching the archives that is is not possible to adjust the halftone color. arrgh!
    Clark
    (...still teaching this dog new tricks...)
    studioCJF
    2001-11
    Antwerp, Belgium
    480
    Thanks for the confirmation Mr. G
    allways nice to be part of the bugbuster team
    I ain't afraid of no bug!
    2006-10
    Cape Town
    94
    I find that I still have this problem with Revit 9.1 If I override only the colour, the lineweight changes to 1. Is this stil a bug?
    All AUGI, all the time DoTheBIM's Avatar
    2005-02
    Central PA, USA
    753
    still happening in 2008 as well... I'm turning it in case no one else did or it needs another vote.
  1. Override Color
    By itssoftmech in forum NavisWorks - General
    Last Post: 2010-03-01, 03:50 AM
  2. Projection/Surface Line Color Override negates Line Weight
    By nosten in forum Revit Architecture - General
    Last Post: 2008-09-30, 07:57 PM
  3. Line color override but still print black
    By ando_mn in forum Revit Architecture - General
    Last Post: 2007-05-10, 02:26 PM
  4. Override Pattern Color affects Color Fills
    By dbaldacchino in forum Revit Architecture - General
    Last Post: 2006-01-13, 07:06 PM
  5. Dim Style Override
    By djahnke in forum AutoCAD General
    Last Post: 2005-01-18, 11:29 PM
