Hi All,
I'm after some Technical advice if possible, I work within the IT industry and our customer is using the AutoCAD software however there having a problem opening large models within the inventor software.
We appear to be getting an error which states
"Your Inventor session has used up more than 80% of the available process address space" (4096MB)
The machine was running Windows XP 32BIT with 4GB RAM, 3.25GB usable, we have since upgraded onto a 64BIt OS and have put an additional 4GB of RAM into the system but still appear to be getting the above error message, I understand you can edit some registry settings to that you get the error message at 90/95% of usage but i'd much perfer to figure out a way of fixing the problem without having to do that.
Any help is appreicated.
Thanks
